Help Injector Questions
02Oilburner
SDD Power Hungry
Raleigh, NC
I have a shot #8 injector. I have read some posts about Beans Diesel Performance for getting some injectors. My question is can I run Beans stage 2 Injectors in my truck with the stock turbo? I have a new Adrenaline HPOP so oil shouldnt be an issue correct? If these will not work how about Beans Stage 1 injectors? Thanks for your help!
yes you can run stage 2 injectors with the stock turbo however you will have smoke problems on the top end and will have the fuel to easily kill the stock turbo if you lay into it for too long. If a turbo upgrade is in your planned future then stage 2 injectors would be a good step if you are planning on staying with the stock turbo then stage 1's are going to be more than enough and offer more smoke control on the low end.
With you adrenaline HPOP oil pressure should not be an issue with either stage 1 or 2 as they both use the same amount of oil which a healthy stock 17° SD HPOP will support
FlorWhitfe
