roozterdvx
started the truck up,let it warm up in the driveway for a few mins and nothing out of the ordinary
drove 2 miles to the gas station and put in 15gals of fuel, left the truck idling while pumping fuel, running fine
go to pull out from the station, and the idle dropped and engine stalled
cranks and won't start
called a buddy and towed the truck home
tried starting again and nothing, just turns over, doesn't start
at 1 point it sputtered a little after numerous attempts of starting but won't light off
did some reading and figured I'd start with the CPS, (still have the original OEM 132000 miles)
put a new gray CPS in and still just cranks and won't start
disconnected the batteries for 30mins, cleaned the terminals and reconnected
cranked her over and she lit! oh joy, my baby is fixed!...NOT!
let her warm up a few mins and she starts sputtering then seems like it dropped 4 cyls, (loping really bad)
gave it some throttle and it smoothed out, back to idle and loping bad then died
tried to restart and it lit off but loped for 2 secs, then died
cranked it over again and nothing, just cranks but won't start
I also tried diconnecting the ICP sensor with the same results
I did open the drain on the back of the filter housing and clean fuel came out.
(I used a hose and clear bottle to contain the fuel)
I also turned the key to the on position with the drain opened and it looked like a steady stream of fuel coming out and almost filled a 2 liter bottle in a short time.
This ordeal started 2 days ago.
Today, I changed out the IPR...
...drained the HPOP res with a hand vac pump and refilled with fresh Rotella 15w40 to within 1/2" of the top
Still no start, just cranks and not even a hint of firing up.
Daylight is gone so tomorrow after work, I am goin to pull the valve covers to check the UVCH connections.
any help is appreciated
