Help Code p1211
94f450sd
certified nutjob
plymouth,ma
check your IPR.make sure the cheesey little nut that holds the solenoid on is tight.check the wireing to the IPR as fuel that gets spilled during a filter change gets down into the wireing and the IPR connector and turns them into mush causing the wires to short out.
97CREWCABPSD
Smoke What Smoke Officer?
Salem, OR
so i have found that the wires in the plug were uninsulated for about 3/4" outside of the plug and when installed they were twisted together i also found that the piston in the IPR was seized in the open position. ithink i found my problems. now to find a turbo that will survive.
Ricksofla
