Help changed fuel fitler and still leaking fuel lots
Wood County Tx
sam
me to,
are you talking about the one around the filter itself right?
not the cap
most caps have a flatish taper looking ring thing and the filter element has a round one that goes flat sided after its in a while,:dunno
but nowdays anything is possible.
if i remember right.:dunno
s d mills
Close to the real OC 47462
Nah....I'm talking about the one around the cap. The old O-ring was flat side up so I installed the new one the same way....no leak. Several times now I've read I installed it wrong and I'm about to conclude that even though it's wrong, that I got lucky and maybe crimping/bunching up is more a factor in leakage than which way it's put in.:dunno
2K more miles and I'll be taking another look at it.
Wood County Tx
yep all the leaks i had was due to the ring bunching up or part sliding down as it tighted
sure makes for a nice stream if its just right:roflmao :D
Brad1103
