Help! Belching White Smoke
focus1
IL.
Smoke
White smoke is over fueling, unburnt fuel a 6.4 should never do that, could be bad fuel ,sticking leaking injector or software. Might need a new program. if it gets worse or keeps doing it why not ask your dealer?
Hardrock_F250
Denmark, SC
Mine was pouring out white smoke on a slow to regular accleration while the humidity was high. There is a TSB on this problem, I had my intercooler replaced and reflashed the PCM and IC, and this stopped the white smoke problem. Here is the TSB.
johnkid
CA , HERMOSA BEACH
so i read that attachment , now i finally understand , like it says it happens during a moderate to full throttle which i sometimes do b/c i live on a busy street and sometimes have to lay on it to get in with the flow of early mornin traffic on a residential street hahaha but yea its very short burst of white smoke say about 30ft 3 ft in diameter , but this is after i had my pcm reflashed & new radiator put in my truck was built in march 07' and as of now until its fixed im not runin a programmer b/c this new software wont let my programmer re-install after re-flashin the programmer multiple times the guys at PPE are trying to write to new software they say ford has really cracked down should get it back this comin week(PROGRAMMER) , but also i have noticed smokin durin regen like when im moderate to full throttle to make a light it burps out some but very minimal , im gonna have to fall on the fact of it could be a mix of the bad fuel and the temps outside i dont think i have a sticking injector well at least i hope !...................so could i be due for a new charge air cooler assembly ?
Pm_guru
