ernestbaca57
I am new here and I am glad to be part of this online community. I have a problem with my powerstoke diesel. It was leaking some fluid under the truck and I could not determine if it was oil or fuel. It appeared to me to be fuel. I could also see that it looked like it was leaking out of the exhaust but I could not see it leaking. I decided to remove the turbo because I believe the leak could be coming from the fuel lines underneath the turbo. I feel once I remove the turbo I can see where the leak is coming from, hopefully. The rear bolts on the back of the pedestal are most definitely a challenge to say the least! I was wondering if anybody has found a way to get those back bolts off without losing your sanity? Those engineers are Ford should have some of this fun also, not just me! Am I going in the right direction with my diagnosis so far? Any help is deeply appreciated. Thank you very much. If anybody out there needs any Farrier advise I can help you out there.http://www.superdutydiesel.com/foru...ydiesel.com/forums/images/smilies/bowdown.gif
