Dec 18, 2007 #1 2001Stroke Full Access Member Joined Jan 11, 2006 Messages 83 Reaction score 0 Location Abilene, TX The plastic on my headlight assembly is getting pretty yellow. Will the 2003 headlight assembly fit on my 2001?
Dec 18, 2007 #2 Buffs F-350 Full Access Member Joined Jan 18, 2007 Messages 361 Reaction score 0 Location New Jersey U.S.A It should be a direct swap.
Dec 18, 2007 #3 architect-builder Full Access Member Joined Apr 6, 2005 Messages 803 Reaction score 4 Location Jerome, Idaho Yes, 02-04 lights are a direct swap. Or with a little more work, (upgrade harness and a little modifying of the header panel) you can install the 05-07 lights. Hope it helps. Barrett
Dec 18, 2007 #4 B BIG JOE Full Access Member Joined Apr 6, 2005 Messages 5,423 Reaction score 55 Location CenCal For $209.00 dollars you could get a pair of Diamond Clears at Truck Accessories | Pickup Truck Accessories & Truck Performance Parts | Stylin' Trucks I bought a pair and really like'm. Very, Very good Low and High Beam pattern. Plug'n Play install. Item # 111023ANZ
