iracemine
black and tan
im not sure its used on startup. only on high idle on cold day/night like chicago is having now. It helps bring the operating temp up quicker and keeps it up here in chicago when its 1deg or less out here.
Got to this shortcut and you'll be in the right direction, But be aware that in low temperatures if you do not plug the truck in you will have a hard start condition, I agree/disagree with Big Joe cause he's in California and your in Indiana, temps are much different between those two locations.
I totally agree.. and didn't mean to sound like: Rip the dang thing out'n throw it away..it probably serves a good purpose in Cooold weather... No Doubt.
AIH Delete Plug
IHC---You are probably right since Indiana temps and weather are vastly more variable/cold than Cal. It may not he worth the effort. PS: I saw your reply regarding newer rearview mirrows. Do you know if I can easily upgrade my 01 mirrors for newer ones with turn signals and heat? What years could replace my 01 ? Thanks for all your help IHCGot to this shortcut and you'll be in the right direction, But be aware that in low temperatures if you do not plug the truck in you will have a hard start condition, I agree/disagree with Big Joe cause he's in California and your in Indiana, temps are much different between those two locations.
AIH Delete Plug
