head studs
melmount
greensboro nc
can arp head studs be reused? or is it a one time deal like the ford factory bolts? i would think they could be used a second time if a head had to be removed? just curious?
thanks:dunno
keanoknick
Big Stroker
Cowtown TEXAS
Before I bought mine, I spoke directly with ARP, and they said as long as they are correctly installed that they can be reused, just make sure you use their assembly lube whenever you tighten them down. :sweet
Maxtor
Redding
My :2c is that since you will have the engine apart, might as well buy new studs, and you will not be worrying about them failing. One broken stud will ruin your day.
