head studs installation
hotrodhauler
wi
i have a 2006 and want to put arp head studs in.
can you get the studs installed without taking the engine out or lifting the body off?
i heard the trick of using rubber band to hold the bolts up while putting the head on, i was thinking this my work on the studs as well. any thoughts or suggestions.....
Thanks Cory
6.0PSD777
Mass
It can be done, but is labor intensive, if you have access to a lift its alot easier to lift the cab off and do it.
Brad1103
