Yeah, you have to run it at or above 2000 rpm for about 30 min as soon as you get it in. Also remember you installed only 1 injector, that means that cylinder is in prime working condition and the other 7 are probably gummed up and not as efficient as the newer one. Did you remove the drain plugs from the heads before installing the new injector?
