Hard Start...Replaced CPS did not cure all
PSDfreak said:
Awesome, thanks for the pic...What am I looking for in that IPR?? "stickyness"?
-Casey
Here is a real good article concerning the IPR vavle written by a guy with some very "colorful" history. Put his history behind and read the article as it is worth your time.
IPR info.
IPR o-rings are notoroious for giving hard hot starts because the oil will easily blow past the ipr o-ring and you can't build pressure.
As for stickyness just rattle it around and see if it rattles if it does then it's good clean it off with some brake cleaner or carb cleaner & reinstall. with a set of new o-rings.
hheynow
Señor Aceite de Soja
Northern California
95_stroker said:
IPR failure should give you hard starts when warm and a surging idle when warm also.
After reading this thread I believe I have an IPR issue too. Once warm I have a distinct surging idle but the scanner shows no codes and passes.
Now thinking back on THIS PREVIOUS THREAD, maybe that's my problem? :dunno
JOAT
I Found Nemo!
The West Coast
PSDfreak said:
It seems like it is gettting easier and easier to throw CELs when under accelteration (even in Econo mode on the chip).
Sounds like IPR o-rings would be a good starting point. If you're gonna be down in the east bay anytime soon shoot me a PM and I'll pull the codes for you.
PSDfreak
Diesel-a-holic
Chico, CA & Newcastle, CA
Hey Don...Do you know which part number is current on your list for the IPR o-rings?? Is it the one ending in AN or AA?? (Ford Part #) I'm getting mixed reactions from the internet and I'm sure you know what I am talking about when I say sometimes those guys behind the parts counters at dealers are not the sharpest tacks in the box. :whah
Thanks,
Casey
I've come to learn that those Ford parts guys really dont like you coming in to them with PN#"s either.:rolleyes:
94f450sd
certified nutjob
plymouth,ma
actually, the dealler i deal with loves it when i have part numbers,even though she normally knows the part number of what i need without looking it up.but the computer she uses sux at finding stuff.
PSDfreak
Diesel-a-holic
It most definetely depends on the dealer...up north they are real good (helpful, informed etc...) here in the bar area...not so much
Ricksofla
