Had my codes scanned, now what?
forumpete58
Kansas City, MO
I posted a couple days ago about the problems I've been having with my PSD; rough, high idle, no power over 2k, constant SES. I just had my codes scanned and here's what turned up. P0602, P0605, P1211,& P1690. Which I believe is: Control Module Programming Error, Internal Control Module ROM Error, ICP Not Controllable - Pressure Abow/Below Desired, and Wastegate Control Valve Malfunction. Also I've discovered that the power doesn't cut out at 2K, it cuts out at a certain throttle position; if pressure is applied beyond a certain point engine just revs with no power.
Thanks guys!
txastuff79
texas
install a new pcm and your done. sounds like a pcm. but wait to see what other people say first.
