GPS vs Speed-O-Meter
I been watching my GPS and sometimes it is slower than my Speed-O-Meter, How does yours check out. Today it was cold out and they were right on.:dunno
the factory speedo's are "GENEROUS" at best....depending on
my acutal speed i can be anywhere from 3 to 5 mph off at a minimum.
the GPS will be more accurate.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
With the factory 265 tires, the speedo was about 2 mph more than what the roadside radar said. When I went to 285 tires, the speedo was dead-on to what the same radar unit says, but now the odometer reads about 2% to 3% less than actual mileage based on measured miles or GPS.
you should find that it varies by speed...it might be spot on @ 55 but
at 80 itll be off several mph.
Robert can tell em that next time...
"Uh sir, when's the last time you had that thing calibrated ?" :D
You can actually ask to the see a certificate of calibration, and if its not up to date, you can beat the ticket by a technicality.
They showed it on some TV show once.
