Got stuck today
Stroked68
This is FORD Country
Eudora, KS
There are tags on the axle housings that will tell you the gear ratio and if you have posi or not. There are a bunch of codes to tell you, so post the codes and we can break them down.
Dave :)
Will do! What oils and additives should I use in the front and rear ends? Def need to change that stuff.
Pm_guru
