comment Got "er" done.
preach
Cataula, Ga.
:clap:I got him home. After PCM,TCM,FICM reprogramed. They replaced EGR valve, and MAP sensor. I'll drive him a couple of weeks to see if this was the problem. Is there anything else they should fix, replace, glue, or duct tape while it's still under warranty?:dizzy
atk
Moderator
simcoe, ontario, canada
;tu....unless you are having other problems not much they can do(warranty work)....
if they are going to be gluing or using duct to fix your truck, i would deffinately get another dealership.....:lmao
preach
Cataula, Ga.
:bama Thanks for the feedback. I have to get up at 3.30 a.m. To go make turbine blades for tank engines.:bootyshak Moon ya'll tomorrow.
TacoCat
