GOOOOOfed UP!!!!!
tommyboy411
chattanooga, tn
To make a long story short, I accidentally put 7.5 gallons of gai in my 6.0. I was running low and had to rush my injured puppy to the vet. When I left, I pulled in and pumped the gas and drove 5 miles home before the truck started running like s**t. I guess I'll be draining the fule. Hope I did not fry injectors. Oh yeah, the puppy is going to be fine.
6.0PSD777
Mass
Truck can always be fixed - Glad to hear your puppy is ok ;tu
JRJ04
Houston, TX
drain the fuel, change the filters, and fill fresh diesel. also, add a strong concentration of 2 cycle motor oil...that will help as well. someone else will chime in on how much you should add.
tommyboy411
chattanooga, tn
RE:GOOOOFed UP
$19.04- 2 new 5 gallon fuel cans, siphon pump, hose, and funnel
$76.91- fuel filters from stealership
$26.00- 10 gallons of fuel
$19.00- 36mm and 24mm sockets
$33.62- new upper fuel filter cap (broke the nut on old one)
5 hours spent doing the job.
puppy breath-PRICELESS!!!!!
nascar_fan28
IL
that stinks that happened. sounds like you fixed it. injectors ok? hows she running?
You can't figure the $26.00 into the price as you needed fuel anyway :D
Glad to hear all is OK with truck and puppy.
scottu5
