Gold coolant in Ontario
Lynden-Jeff
Landscaper
Hamilton, Ontario
Hey,
Where can I find gold coolant or the equivelant in ontario without going to a ford dealer? Ive tried Canadian Tire and its no good. Maybe a Carquest or NAPA? Also should I be mixing 50/50 or 70/30.
Cheers
Jeff
Zerex G-05 is the spec. equiv.
Here in the "lower 48" I've found it only in
AUTOZONE Stores....'bout 10.99 per gallon in
100% strength.
atk
Moderator
simcoe, ontario, canada
Hey,
Cheers
Jeff
i know we have at the shop, Zerex gold G05, but i am sure you should be able to find it at carquest or napa or maybe even wal-mart....you should be ok mixing it at 50/50 or even 60/40, but i wouldn`t go much more then that.also use distilled water....if you are in the brantford area(thats where i work), i am sure we could sell you some....:D
Lynden-Jeff
Landscaper
Hamilton, Ontario
I am in Lynden, which is technically hamilton but not far from brantford. I will take a look in carquest and if I can't find any I will let you know. I was actually through simcoe today lol.
Cheers
Jeff
P.S what shop do you work at? Are you a diesel mechanic?
ill ship you some if it helps...w/ the exchange <dollar in the dumper>
rate...tax & shipping it probably wont cost you any more than IF you
could find it local.
FlorWhitfe
