toobsluver
So I have been having these on going cold starting issues with my truck. I tried fixing the harness connector for my glow plugs that is at the valve covers and that had not seem to work. Originally I was only getting the codes for the driver side of the motor. After doing that clip fix, nothing changed and I never persued it further cause it was spring at that point and my Excursion is a weekend vehicle. So now I am looking to change the glow plugs on both sides of the motor and possibly the glow plug circuit module. Not the solenoid looking thing, but the more expensive aluminum brick with about 30 wires coming out of the two harnesses that plug into it. So as of right now, here are the codes I am getting: P0672,P0674,P0675,P0676,P0677,P0678, basically glow plug failure codes last number notes what cylinder.
What brand glow plugs do you guys recommend?
Thanks in advance guys!
