Getting a P0603 code.
Aaron Dennis
Ohio
Hey all,
I have a 04 Ford F250 SD 6.0. I just completed the EGR delete.
Truck started up and ran ok for about 10 minutes. Idles really rough and then dies.
Hooked up a scan tool on it and it was throwing the P0603 Keep Alive Memory code.
Cleaned the connections on it just for S&Gs. Starts on its own sometimes, other times it won't.
I'm trying to figure out if it's the wiring or the PCM itself. I don't want to just keep throwing parts at the truck.
Any ideas? If its the wiring, which wire should I be testing?
bismic1
What are your ICP (psig and volts) and your IPR (% duty cycle) readings when cranking?
Are you getting Sync and FICM Sync when cranking?
RPMs when cranking?
Battery volts when cranking?
FICM MPower and LPower volts when cranking?
What are you using for a code reader (some readers do not read all the codes very well).
PCM's don't fail very often.
01yellerCobra
Cali
Did you check over the recent work and make sure everything is connected? Did you load a tune for the EGR delete? Does it need a tune for that?
bismic1
It doesn't seem like a priority issue to the OP ................
FlorWhitfe
