Genysis/ tire, gear ratio changing
rynarnell
03 6.0 8.0lift on 38"s
alaska
hey does anybody know if you can change the tire size and gear ratio with a genysis scanner?
im not the smartest man, but the gear ratio would have to be changed back at the rear end (i.e. by hand). a scanner aint gonna change that, unless it has 2 legs, 2 arms, 2 hands, 10 fingers, a jack, impact wrench, sockets, etc.
some tuners will reprogram for the bigger tires and the dealer should be able to do that too.
rynarnell
alaska
ya thats what i meant. tire size. I just want to know if the geysis will do it.
rynarnell
alaska
Yes that helps thanks, I guess i will have to go to the dealer.
ktpauley
Schwenksville, Pa.
Hope it helps. The dealer can't reprogram anything less than 601 revs per mile. That typically is a 37" tire. Keith
TacoCat
