Fuel return flow
dpantazis
#12
under the cheddar curtain
something like 50-60 gpm.
the guy who did the tank mod and research had a setup where he measured it as well at to see the bubbles in the stream. he had pics on webshots.
i can not remember his name right now. someone may post it up.
dp
dp
are you talkin about LARRY ?
dpantazis
#12
yes, its 50-60 gpH. my bad.
it was hutchinagusta that i recall giving a number like that. something like a little over a minute to fill a gallon jug. and i think it WAS for SDD, not OBS. my bad again.
hutch- you in here? is the 'data' somewhere?
dennis
93turbo_animal
Marengo,ohio
yeah its gotta be GPH not GPM cause the fuel truck I use to drive would pump 60 GPM but that was thru a 2" hose at about 60 PSI
