hheynow
Señor Aceite de Soja
I had my fuel pump replaced two days ago and all was fine. Today I started on my rear tank of B50 and all was fine. I switched to the front tank of veggie oil and all was fine. When I switched back to the rear tank the truck lost power and started to shake so I pulled off the road. Thinking that my fuel filter was clogged I opened the black lid, but noticed a small vacuum as I unscrewed the lid. The bowl was just about empty. So I'm thinking it could be one of two problems, the new fuel pump is bad (the engine is sucking fuel from the bowl but it is not refilling from the tank) or the fuel pump is good but there is gunk on the rear tank fuel pickup so the bowl won't refill. Could it be something else?
My last fuel pump lasted for 70K which I realize is a short life span BUT I run veggie oil so I'm OK with it. Having a fuel pump for less than 48 hours is unacceptable.
Fortunately I had it towed back to the shop tonight which will be open on Labor Day so they will get on it in the a.m. It just feels better to vent.
