Question Fuel pump help
mustangmuscle
PSL,FL
Going to be installing my 3rd fuel pump in 7 months. Change filter every time and even changed the screen in the tank. Any suggestions what the cause may be? Last pump only lasted a month.
RoyBoy
Diesel Dork
central WI
Did you check the fuel system pressure? Never know if the regulator is stuck or something, also perhaps a wiring or relay problem? What is failing on the pumps, the motor or the actual pump?
scottu5
