hheynow
Señor Aceite de Soja
A strange occurrence is happening the past few days once I start the truck. It starts fine but once I get to the main road (55 mph) I have no power. No matter how much pressure on the go pedal I put, it won't go over 15 mph. I pull off to the side of the road and turn on my high idle for a few minutes then the power returns. I do see a leak in the valley but have not traced it. You all know that I run WVO and both tanks are utilized by the stock fuel pump. I initially thought that the fuel pump might have gotten stuck because of the WVO's stickiness, but I haven't run on my front tank in days. This pump has about 70K on it. The problem only happens the first time I drive it on a given day. All follow up starts are fuel pump problem free.
