Digital Oxygen
Got Boost?
I've done a search for the problem, but I don't think I've found anything.
My 03 (6 liter for those of you who don't realize this is in the 6Liter thread ), started pushing over 150psi worth of fuel pressure. My Gauge only goes to 150SPI and it's over ranging it. Typically, it sits at about 65-70 psi. This happened over the course of about 4 hours. I noticed it when it spiked to 93PSI and about an hour later, it was overranging the gauge sender.
Now, if I get on it, the pressure drops to about 80psi when the motor is under load.
Pulled out the top fuel filter and replaced it (though the old one seemed fairly clean). No luck.
now, I found this thread about high fuel pressure. Are the 7.3 Fuel bowls the same as the 6.0? Do the 6.0's have the little screen in them?
http://www.superdutydiesel.com/forums/showthread.php?t=8845&highlight=fuel+pressure
Thanks for your input.
