Question Fuel Pressure Gauge
bbressler
Happy, TX
You'd probably be alright leaving it...just be sure you've got something with you so if it DOES rupture, you're not stranded... Make sure you insulate the hose from abrasion..
drmjf
Pinole, Kalifornia
I hooked up regular oil pressure gauge to my truck. I did use 1/8" copper line instead of the nylon. 65 psi is not high pressure. It's working for me.
dpantazis
#12
under the cheddar curtain
j:
iirc,the fitting on the fuel bowl is NOT NPT, its a o-ring seal type.
there is a writeup on putting on a guage somewhere that had all the bits and pieces listed. the info might be in the regulated return wiki too.
EDIT: 1/8" NPT to #4JIC in the wiki page,
dp
roosterdiesel
Earl needs B100
Amarillo,TX
You'll need a fitting that's oring boss to go into the filter housing to whatever is on the end of your hose. I don't remember what the o-ring size -4 maybe. ITP sell an adapter to NPT I think.
:dunno I carry the O ring plug fitting that >was< in the filter housing.. in my bed box. (along with all the Other OEM plugs'n fittings from other Mods)
