Fuel Pressure Gauge for 1999 7.3l
IHC Power
STOCK STROKE
Walpole Mass
Fuel Pressure
Typically you get the reading from the back side of the fuel filter bowl.
Tail_Gunner
CRJ & ERJ A&P Mech.
Da U.P.
Make sure you use either an electric gauge or a mechanical with a pressure isolater.
A pressure isolater mounts in the engine compartment. Fuel presure pushes on one side of a diaphram. The diaphram then exerts pressure on the other side which you fill with antifreeze. The pressure line filled with antifreeze goes to your mechanical gauge in the cab. So if you ever spring a leak in the cab, what comes out is antifreeze and not flamable fuel.
