Tell me more about these O-rings. Easy replace ?
Easy fix.
You can get a Fuel/water drain rebuild kit from Ford, or, chase down the proper size O rings (cheaper)... You could also check the SDD Site Sponsors.. they may have them too.
With a mirror, look on the back side of yer filter housing.. yul see the Yellow drain valve lever and associated screws* for the drain valve assembly.
Like TG sez.. put a extension hose on the drain tube (avoids a mess).. loosen the filter lid, drain the housing, remove the filter, remove the whole valve assembly, replace the O rings.. re-install and tighten, the valve assembly, filter and lid. Turn the key on a couple times to purdge (fill) the filter housing. Start the engine and inspect yer work.
Done Deal.
When you say BatterY did you mean Just One ? If so.. you should Allways replace BOTH Battery's on these things..
* Tighter.. is not better. Snug the screws down with Only the same force.. as it took to loosen them.
