fuel leak on top of engine
97powerstroker
north port,fl
i went outside today and started my truck and went inside for a few mins,when i came out there was alittle puddle of fuel underneath of it,so i popped the hood and looked and sawsome type of plug or something dripping fuel,im not sure what its called buts its directly behind the icp plug,and it has like a gold fitting on it and also a red with yellow stripe wire going in it.i can turn the fitting but it doesnt seem to tighten,any ideas?still runs fine
Patrick Feeley
Tehachapi, CA
Sounds like the fuel restriction sensor (notorious for leaking). You can replace the sensor or use a 1/8" pipe plug (just don't overtighten as the housing cracks easily). Cheers!
Isnt that located on the FPR? Sounds to me like he is describing a leak on the head?
97powerstroker
north port,fl
its directly behind the icp plug,i think its the sensor as well,it doesnt always leak and when it does it just drips
FlorWhitfe
