Fuel Issues need help asap
cjchamp
TOW_RIG
Littlefun
To make a long story short I have a leak off a high pressure line from the back of the fuel filter/ canister sitting in the middle of the engine...the line is a hard line that has aprox. 1 inch hose that attaches to a small box with 4 screws holding this in....the line only leaks when I shut the engine down....:dunno Tomorrow I will attempt to fix this. Does anyone have any idea why this could be leaking(bad o ring?) I need my truck by monday...anyone know how to dismantle it? is there a special way since its a High pressure line?
Thanks in advance
Josh
Oh, its a 2000 7.3
silverF250
Arnold, Mo
My brother just had one that was leaking from rubbing the gpr bracket. With it leaking it isn't under any pressure. (At least his wasn't).
Thanks in advance
Josh
Oh, its a 2000 7.3
If I'm understanding what you're describing... It sounds like the filter drain valve assembly. They do that.. the O rings degrade and leak.
Quik fix. Just buy a re-build kit from Ford, IH or a good local parts house.
:dunno
Blue99SD
Freeman's Offroad
Liberty,IN
If its the line that attaches to the fuel drian valve, there are 2 orings that seal it. Just did mine yesterday,take the 4 torx screws out and the valve will come off. Ford wanted $30 -$40 for an assortment of orings, I orderd mine from Pure Diesel Power for $17 and had them in about 3 days.
Jinco
CO
Here is the specification of the o rings you need. You can get them at Grainger, McMaster-Carr, or probably any hydraulic shop for pennies.
"O-Ring, Viton, AS568A Dash Number 202, Fractional Width 1/8 In, Actual Width 0.139 In, Black Color, Round Cross Section Shape, Inside Dia 1/4 In"
