addicted
Well I had my new injectors installed and everything was great. Then my wife was driving and the fuel filter light came on. She made it another few miles and it completly crapped out on her. I brought a new filter to put in it but the one in there wasn't that bad (only 100 miles on it). Still no start.
I had it towed to a shop (something I usually don't do) and they said they were not getting any fuel pressure out of the pump. I figured a clogged tank screen but I bought a new pump and put it in anyway. The other one was good by the way. After that I still couldn't get it to start. Then I looked at the small screen on the FPR and it was clogged. I think this is my FPR screen???? I'm not sure. It is that screen at the top of the fuel bowl as part of that regulator on the top drivers side of the fuel bowl. None the less I cleaned it. Then I had my neighbor hold the schrader valve until all of the air got out and then it ran fine. About 100 miles later and light comes on. No issues at all and then all of the sudden it died and I'm not getting fuel into the bowl again. Fuel filter is clean.
Anyone have any ideas? I'm leaving on a 2500 mile road trip towing a trailer in 2 days and need to get to the root of the problem. This is our first vacation in a couple of years and will be the last and it is quickly going down the drain.
All 3 of my tanks doesn't help with the issue so I don't think it is a clogged tank screen though it could be. Should my fuel lines drain from the stock tanks if I unhook them? Becuase they don't.
Thank you for any help.
