Can anybody post some pictures of where the port is for draining the fuel filter bowl. I'd like to add some line to the end of it so fuel doesn't leak all over the place when I change out the filter
Rich
I don't have any photos but if you lay on the ground 2/3 towards passenger side and look up you'll see the positive cable that goes to the starter is clamped with a flat metal bracket. Behind that you'll see the negative cable where it's grounded to the frame. Look for a metal tube that's behind that. It follows the engine but ends behind plain view. That's the fuel drain tube. I put a piece of hose (don't remember the I.D.) on it and draining the fuel is not messy anymore.
CLICK HERE to see where mine is. The picture is taken from the front, the tire you see is the passenger side front tire. I used 5/16" fuel line wire tied to one of the brake lines. The lower end of the pipe where the fuel comes out is just out of site up toward the engine. You can see the fuel line and the two white wire ties in the picture.
