Over the last 4 years of fueling up, the fuel cap has slowly scratched the paint from when it hangs down during fuel up.
I drilled a hole into the hinge and simply put a stainless steel screw, washer, and nut thru the hole.
Then I drilled a hole in the fuel cap teather and then all you have to do is hang the cap on the screw.
Keeps the paint from being scratched up.
