Metalhead
I'm wanting to replace the rear seal on my right side front hub, so that the vacuum hub lock can finally work. Awhile back, I narrowed down my hub locking problem to the right side hub. If I plug the line at the right hub, the left hub locks & unlocks perfectly, and if I swap hubs from side to side, the left side still locks perfectly, while the right side leaks.
What I'm wanting to know, since these hubs are sealed units, can I just replace the rear seals on them? I will be replacing the right side axle tube seal at the same time (has come loose). I just want to get my auto hub system back to working order.
I'll be replacing both left & right sides since I'm at it.
Thanks
Thanks
