ForumBlue
CDXX
Where can I find replacements for the front end Bump Stops for a 02, 7.3, 4WD, Excursion. Ford wants 45 bucks each for these hunks of rubber and I was wondering if there was something else out there for a reasonable price. I'm not sure if Bump Stop is the actual name but the part number on the part itself is YC35 3020 AC
EDIT: I just noticed that there is a bolt hole between the 2 holes where the OEMs came off. Can I use the ones like are on the rear with the one bolt that goes up through the middle of the stop itself or is there a reason why the fronts need to have the 2 hole mounts ?
Thanks.
Thanks.
