Metalhead
I was checking things out on the underside of my truck this morning, and discovered that the right-side front axle shaft main seal is loose. It is able to ride between the axle body and U-joint body of the axle shaft. I know I need to fix this soon, but am wondering what could've gotten into the axle since this has been the case. Are there more seals inside of the axle tube that would keep dust from getting into the diff? I don't see any oil drips or stains from the axle tube, so I'm thinking it might not be a bad situation.
I haven't gone through a teardown or rebuild of this front axle yet, and am just wondering if there's anything bad that could happen with this being the case.
