French fry or Chicken exhaust?
W4RLR
High Tech Hillbilly
Sewanee, TN
Chinese food...ummm good, but an hour after I get behind someone using WVO from a Chinese restaurant and breathe those fumes, I get the munchies SO BAD! -popcorn
hheynow
Señor Aceite de Soja
Northern California
Got my first chance to drive behind a french fried diesel the other day. Funny thing...I'm driving on the coast road (Hwy 1) by the ocean with obviously no fast food establishments for miles wondering who the heck is frying potatoes :dunno ? Then it clicked...:D I can't wait to drive behind a diesel turkey mobile. :roflmao
HCAbowman
Fayetteville, NC
So I gotta ask you guys...are you actually running this stuff through your trucks? Im a "gasser" as budro puts it... :D :D ...how do you keep things from congealing (sp) in the tank and injectors ect....Im really curious?
ChrisMartinTX
97 F-250
Bryan, TX
i wish someone around here would give me oil! everyone is getting paid for their waste oil by this company out of houston.
KansasDiesel
fly'n low on WVO
Kansas City area
Bowman, I mix some with diesel in the heat of the summer about 20%, But my WVO tank and lines are heated to thin the oil to the same consistancy as diesel. Once the truck gets up to temp, I switch to veg oil and I am off and running. You must remember that a diesel engine fuel is ignited but compression and not a spark, the heat in the compression will ignite almost any oil. There is a BIG process to make sure the oil is clean enough so you don't mess up your injectors.
:cowboy:
KansasDiesel
fly'n low on WVO
Kansas City area
Got the same problem here.... I am lossing sources because of this also. I may have to start paying for it. I am dowm to about 30 gals left in my back up supply. :(
HCAbowman
Fayetteville, NC
:cowboy:
Thats awesome....I kinda figured you would have to filter the heck outta it, or something so ya didnt have chunks of fry or whatever floating around it!! Thank you...Im starting to think I need to go truck shopping this weekend...LOL!!
KansasDiesel
fly'n low on WVO
Kansas City area
There is a filtering and dewatering process you must go thru but once you get your proceedure down it is a piece of cake. I filter mine 3 times and the final is filtered to between 10 and 5 microns. Note that if you live in a cold climiate that you should not mix it with diesel because the oil will gell up and cause problems, that is why we install a totally different fuel system to run SVO/WVO with heated tanks and fuel lines and even heated fuel filters. :cowboy:
You still have to run diesel to start and stop, You never want to start using SVO/WVO until your engine is up to temp.
Ricksofla
