Ford recall 4.5M Vehicles - speed control deactivation switch
arizona
CA
I have the new fused wiring and do not know where to look to replace. Can anybody point me in the right location?
hheynow
Señor Aceite de Soja
Northern California
Brought mine in for that 09S09 recall last Saturday. They also said there was a recall for the CPS so they did both. They said it would take two hours :eek: but I was out the door in 30 minutes... :sweet ...but I was the first appointment of the day.
arizona
CA
Alright, I found it. Thanks!. My cc has not worked for a while, and the new fused wiring was not a fix. I had replaced a bad lamp in the third brake light because I read it might be wired to disable cc if burnt out. That didn't fix it. I will need the switch for sure now that I see mine is one of the leaking ones. Time to detail my engine compartment and locate and identify ALL of these connectors and devices once and for all:dizzy
stroker21
Midland, TX
I took my X in the other day to have the fuse and cps done. They had me out in 15 mins.
sagebel
Stock? Pfft!
Albuquerque, NM
Because when they reflash your PCM with "updates" and your truck will no longer run with your chip or they burn over custom tuning, it's a good reason to kick someone's ***.
Brad1103
