Fluid Capacities?
JSPulliam21
Uva Uvam Vivendo Vari Fit
Castalian Springs, TN
I did a search, but I could not come up with anything definative. Could someone please list the fluid capacities for a 2002 F-350 auto 4x4 dually? Transfer case and front and rear axles. I am going to place an AMSOIL order for my truck and my father's, and I need to have an exact amount since it is $$$$$ :sweet :thanks
dboyw
Lancaster, PA
From the Amsoil Product Application.
CAPACITIES
Engine, with filter..........15.0 quarts[1]
Cooling System, Initial Fill..........33.0 quarts
Automatic Transmission, 4R100 Initial Fill..........6.5 quarts[2]
Automatic Transmission, Total Fill
4 speed 20 plate 4R100..........17.0 quarts
4 speed 26 plate 4R100..........18.0 quarts
4 speed ..........18.0 quarts
Manual Transmission, 6-SPD W/ OCOOL..........13.0 pints
Manual Transmission, 6-SPD W/O OCOOL..........12.0 pints
Manual Transmission, 5-SPD Mazda..........7.6 pints
Manual Transmission, 5-SPD ZF..........6.8 pints
Differential, Dana 135 Rear..........31.0 pints
Differential, with 10.5 ring gear Rear..........7.0 pints
Differential, Dana 80 Rear..........8.4 pints
Differential, Dana 50 Front..........3.8 pints
Differential, Dana 60 Front..........5.7 pints
Transfer Case,..........4.0 pints
Hope this helps. I finally have Amsoil everywhere I can.
dboyw
Lancaster, PA
Goto Amsoil.com and about dead center of the page you will see a red rectanguler box that says Amsoil Product Application Guide. Click and away you go.
Brad1103
