You can use a volt/ohm meter and measure from the tip of the glow plug to the ground. If it is good, you should see about one ohm. If it is open (no reading or infinity) then it is bad.
how do you check the gps.
151,000 i can hear the solenoid click when i turn key guess ill have to check gps
no engine lite on might need to take to a shop
no scanner either
