Firestone Destination T/A Tires ?????
anybody ever used these tires before? if so, how did you like them.
my cousin the dealer has a F350XLT with these tires on it, almost new tires, and i was thinking about trading him a set of lariat wheels for the tires, if he will.
also, how much do they cost???? thanks.
To give you a starting point check out the rack's Survey and also their pricing.
They look really good from a performance standpoint:sweet
whats their Load Range Rating ? they dont look like E rated tires...
yep, these are D load range tires. they may not matter tho, i dont pull a trailer anymore.
but, i checked the tread depth with my gauge, and the front tires had about 8/32 on each, and the rears have 12/32.
dont think i will go for it.
the 265's on my truck look so small now, after i had the 1.5" add-a-leaf spring added to the front.
if i could make a good trade for some BFG's that are 285/75R/16, i think that would feel the wheel well up better.
just thinkin out loud.
understood on the load range issue...hell i haul people more than anything,
by all rights i should be driving a station wagon (and i mean like a 70s
wagon, not an nice X)
atk
Moderator
simcoe, ontario, canada
good choice on passing on those tires.... i had a set on a previous truck and wasn`t to happy with them, but i haven`t been a firestone tire fan anyway...
i have been thinking about 285, but i might even go to 305, or even 315`s....
haven`t decided yet....:sly ....:D
f_250pstroke02
Baton Rouge/New Orleans, LA
Bama and ATK,
If you want to run a little bigger tire with a "stock" stance I run 305/70R/16 on my truck. They only rub on really tight turns. It is a 2002 7.3, not sure on the clearence with ya'lls body style, and I'm not exactly sure how the tire sizes work. 285/75R/16 vs. 305/70R/16 = same size?
Bama and ATK,
hey ben, can answer me this. i have always been confused as to exactly what the numbers mean, exxcept for the rim size. so what do they mean.
for example, my tires: 265??? 75R???
i'm sure it has something to do with tread thickness, or tire width, im not sure.
BTW. i just had a 1.5" add-a-leaf installed, so the stance looks really great now, but the 265's seem so small on it.
f_250pstroke02
I'm not really sure myself Stephen. Correct me if I'm wrong guys (and I'm sure I am) but I believe the larger number using a 305/70R/16 is the width in millimeters and the 70 is the percent of the sidewall height based on the width of the tire.
