Well i finally added my edge tuner to my completely stock 06 f350 at 120K.
Yesterday i took it out for a spin on the #2 setting which is 60 HP and 100FTLB torrque. From a dead stop it still takes off the same but after about 20' it really cranks it on (BLOWS SERIOUS BLACK SMOKE).
I did an EGT run to see what i could max that at and it hit 1500 degrees at 92MPH running wide open. That one kind of surprised me.Makes me wonder what the EGT would be if i went up two more settings to the performance mode.
The EOT and the ECT run about 10 to 15 degrees apart and on a 5 mile uphill 8% grade at 65MPH it got as far as 18 degrees apart but my local guy says if it gets 30 degrees split after everything has stabilized on a long pull then the coolant side of the oil cooler is plugged so i guess im okay for now.
Overall I have had a increase of about 1.5 MPG on the highway so that is good. Other than that i dont think i would really need this thing unless im pulling my RV which is why i bought it in the first place.
