Factory fog lights not working after jump start
AK Rover
Kenai, Alaska
I installed my 4 new Lightforce HID lights last night and while working my weak batteries drained to the point of requiring a jump start. Before the jump start all lights worked fine, after the jump start my factory fog lights won't turn on. I was wondering if anyone else had experienced something similar? Is there a protection circuit that won't allow the fog lights to turn on unless the battery is good?
TIA
IHC Power
STOCK STROKE
Walpole Mass
Fog lights
Yea I hate when that happens, happened to me last week putting my gauges in except for the fog light thing. Check the fuse, headlight switch, bulbs. What did you use to jump your truck?
FWIW ? To avoid this kinda thing, I always try to use something Other Than.. the Negative Battery Post.. for a Grounding point, on the vehicle being Jump Started... AND.. on my truck too.
(Like the lower hood latch ?)
:dunno
AK Rover
Kenai, Alaska
Thanks for the responses. I used the battery charger at my work to do the jump start. Going to check fuses right now and if that isn't the problem I'll pull the bulbs out and check them when I get to work can have a warm shop to work in.
AK Rover
Kenai, Alaska
Turns out the problem was as simple as a blown fuse. Replaced the fuse and no problem since.
AK Rover
Kenai, Alaska
