We are working on a F550 boom truck (Im not sure on exact year, 01 maybe) with a 4r100 and a Chelsea "power shift" 242/244 PTO running an Eaton hydraulic pump.
Problem:
Little/No flow or pressure from PTO driven hydraulic pump
The flow meter shows 4gpm when pto first engages, almost instantly drops to 0. No change in engine RPM when line restriction is added, no hydraulic pressure built.
Troubleshooting steps taken:
Replaced old worn out hydraulic pump with brand new Eaton gear pump.
Tested transmission line pressure going to PTO clutch pack, found 145 PSI (Ford spec says 130).
Tested engagement solenoid is working (our 145psi was read after the solenoid)
Other info:
Noted that the engagement pressure takes almost 10 mins to bleed off from 145psi to 0, thinking it should almost instantly go to 0. Not sure if a return line is plugged or what the deal is.
Truck runs at the correct 1200 RPM with PTO engaged.
Our thoughts:
We are thinking that since the engagement pressure takes so long to bleed down the clutches in the PTO have been rubbing and are fried. Not sure how to test this theory besides taking the PTO off and tearing it apart.
Tomorrow we are going to disconnect the truck mounted hoses and run a feed/return straight into a 5 gal bucket with our pressure tester inline to see what happens, If we have good pressure and flow then it is obvious there is a restriction somewhere in the truck mounted hydraulics.
Im just looking for some other ideas/things to check while we are at it before we get into this too deep.
If someone could find a Chelsea troubleshooting guide it would be nice, I have looked and couldnt find one.
32 is the clutch pack we are thinking is fried.
Thanks,
Dylan
Problem:
Other info:
Our thoughts:
Thanks,
Dylan
