F250 Super duty 6.0 cold engine miss?
Cold Start and cold missing are possible problems with the FICM. Mine gave me fits about a yaer and half ago. I suspected the FICM and I took it to my dealer and they changed it for something like $650.00. Runs great ever since. Get it scanned for FICM problem codes.
hdjeff
Medina, Ohio
Its probably a sticking spool valve in the injector, try Rev X like before, had same issue with mine, slight improvement with Rev X, but crapped out 2 injectors, failed balance test. Ended up replacing injectors, no more problem, FICM tested out good. Have a dealer or good diesel shop test the injectors unless you have a good scanner.
Ricksofla
