F250 sunroof Leaking
Smoky
Mississippi State
Does anyone know about the drain tubes????????????
:confused:
I found the front leak in the floorboard. It was a gromet in the right side of the firewall that has an orange wire runnung thru it. It may be an aftermarket wire. I put the gromet back in place and that stopped it in the front. The moonroof drain is still leaking and it drains to the rear of the cab. I believe it is stopped up. Anyway the water drips into the back corner from the ceiling, It is right where the drain bends at the door.
Do I need a new drain tube?
Smoky
Mississippi State
Sunroof Leaking FIXED
Too much water was leaking around the sunroof seal and the tube could not take that much to drain off at a time. Rubber seal about the glass sunroof was replaced and no leak now.
;tu
