ponyexpress94
Diesel Power Junkie
Wow thanks Pony and Big Joe. Theres a lot to consider here. I have had the truck for 2 years and just acquired the trailer on a trade. I took it by flying j scales on the drive home and thats how I found out the weight.
I have previously weighed the truck and know it weighs 8600 lbs. It is f250 super cab 6.0l powerstroke, with automatic.
When I looked at the scale ticket I saw that the gvw was 19200 lbs. It showed 5400 lbs on the rear axle
I should say that of course the trailer was empty. We're in the process of outfitting it and will look at the weights again when we are done.
The biggest reason I wanted to keep this particular truck is because it is paid for...
Thanks again
Denny
Well it sounds like you understand what numbers you need to work with to figure out your capabilities with the truck as it sits now. I can't remember the rear axle rating for a 2004 F-250 but I'm guessing that 5,400 lbs. is probably getting close. And notice that each rear tire is rated at exactly half of the Max Rear Gross Axle Weight Rating. Once you exceed Rear GAWR you'll be gambling with your possesions, so please be safe. BigJoe gave you some suggestions on mods so good luck with your decision.
