f-350 down going on 3wks at dealer
eddiebj
I need help, i have a f-350 2003 6.0 powerstroke super dually..check gauge lite is on and oil pressure gauge shows low when vehicle is started..when accelerated lite goes off and oli pressure gauge shows working correct..mechanics trying to found where possible leak is in system, they have motor apart as of now...i had similar problem 5 months ago with vehicle turning over but not starting..they finally accessed it to oil pressure pump and a sensor vehicle was down 3 months...i have 165,000 miles on vehicle i am a carhauler,use vehicle to pull a 53ft gooseneck trailer haul 3 to 4 vehicles..can u help with what problem may be....thxs...ebj
budtoh3zo
Little Smoky, Ab, Canada
The factory oil pressure gage is a joke, its only a pressure switch it switches on at 5 psi. All i can guess is a faulty switch or oil pump gone
Kleetus
Butler PA
I agree... Oil gauge is a bad joke, should just be a pass fail light... My guess would be the oil pump as well. If you already lost the HP pump for the injectors, I woudn't be surprised if there was significant wear on the main pump.
TacoCat
