The day you start putting extra fuel tanks in the 08 SuperDuty is the day you can kiss your fuel gauge goodbye.... those ICM's HATE extra tank setups (unless you know somebody that can change the configuration of the cluster).
So then i guess if somebody still wanted an aftermarket tank, the only option would be to get an aftermarket guage and sending unit. I just want to make sure there arent going to be any codes causing problems with day to day operations. I can deal with the display showing no fuel and having an aftermarket gauge but if it starts tripping codes that need to be reset by dealers, then we are getting into some serious problems.
Bush, do you have AutoEnginuity? I can't remember if you said you had it or not.
You would still run into the gauge, check engine light, and low fuel message after running off the secondary tank for a while.
